The MKA participant with the highest actor priority is designated as the key server.
Apply an MKA profile to the port.
Disable MKA on the port before you configure a value for actor priority. Enable MKA on the port after you configure an actor priority value.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/4 Switch:1(config-if)#macsec actor-priority 0x0f
The following table defines parameters for the macsec actor-priority command.
Variable |
Value |
<0x00-0xff> |
Specifies a hexadecimal value for actor priority, which determines key server selection. Lower values indicate a higher priority. The default is 10. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
